[Gdal-dev] Center of polygon
Chapman, Martin
MChapman at sanz.com
Mon Apr 5 16:01:40 EDT 2004
Yo,
I know how to do this in c++ code:
// example method call:
vector< float> pCenter = pPolygon->GetCenter(pPolygon->GetXPoints(),
pPolygon->GetYPoints(), pEx);
// the supporting routines
double CSimpleGeometry::CalculateProjectedArea(vector< float>* pXPoints,
vector< float>* pYPoints)
try
int j = 0;
double nArea = 0.0;
long nSize = pXPoints->size();
if (nSize < 2)
return 0.0;
for (int i = 0; i < nSize; ++i)
j = (i + 1) % nSize;
nArea += pXPoints->at(i) * pYPoints->at(j);
nArea -= pYPoints->at(i) * pXPoints->at(j);
nArea = nArea / 2.0;
return (nArea < 0.0 ? -nArea : nArea);
catch(...)
throw CString("An unspecified error occurred");
vector< float> CSimpleGeometry::GetCenter(vector< float>* pXPoints,
vector< float>* pYPoints, vector< float>* pExtents)
try
float cx = 0.0f;
float cy = 0.0f;
float nArea = (float) CalculateProjectedArea(pXPoints,
pYPoints);
int j = 0;
float nFactor = 0.0f;
vector< float> pCenter;
if (nSize < 2)
pCenter.push_back(0.0f);
return pCenter;
if (nSize == 2)
pCenter.push_back(pXPoints->at(0));
pCenter.push_back(pXPoints->at(1));
return pCenter;
for (int i = 0; i < nSize; i++)
nFactor = pXPoints->at(i) * pYPoints->at(j) -
pXPoints->at(j) * pYPoints->at(i);
cx += (pXPoints->at(i) + pXPoints->at(j)) *
nFactor;
cy += (pYPoints->at(i) + pYPoints->at(j)) *
nFactor;
nArea = nArea * 6.0f;
nFactor = 1 / nArea;
cx = abs(cx * nFactor);
cy = abs(cy * nFactor);
float pXExtents[5] = {pExtents->at(1), pExtents->at(1),
pExtents->at(3), pExtents->at(3), pExtents->at(1)};
float pYExtents[5] = {pExtents->at(2), pExtents->at(0),
pExtents->at(0), pExtents->at(2), pExtents->at(2)};
if ( IsPointInPolygon(5, pXExtents, pYExtents, cx, cy))
pCenter.push_back(cy);
pCenter.push_back(cx);
else if ( IsPointInPolygon(5, pXExtents, pYExtents, cx *
-1.0f, cy))
pCenter.push_back(cx * -1);
else if ( IsPointInPolygon(5, pXExtents, pYExtents, cx,
cy * -1.0f))
pCenter.push_back(cy * -1);
-1.0f, cy * -1.0f))
else
return pCenter;
catch(...)
bool CSimpleGeometry::IsPointInPolygon(int nPolySize, float* pXPoints,
float* pYPoints, float nX, float nY)
try
long i, j;
bool bIsInside = false;
for (i = 0, j = nPolySize - 1; i < nPolySize; j = i++)
if ((((pYPoints[i] <= nY) && (nY < pYPoints[j]))
((pYPoints[j] <= nY) && (nY < pYPoints[i])))
(nX < (pXPoints[j] - pXPoints[i]) *
(nY - pYPoints[i]) / (pYPoints[j] -
pYPoints[i]) + pXPoints[i]))
bIsInside = !bIsInside;
return bIsInside;
catch(...)
vector< float> CSimpleGeometry::GetMidPoint(vector< float>* pPoints)
try
float nY1 = 0.0f, nX1 = 0.0f, nY2 = 0.0f, nX2 = 0.0f,
nDistance = 0.0f;
int j = 0;
vector< float> pMidPoint;
nDistance = (float) GetDistance(pPoints);
float nMidPoint = nDistance / 2;
nDistance = 0.0f;
vector< float>::iterator it;
for (it = pPoints->begin(); it != pPoints->end(); j++)
if (j == 0)
nY1 = *it;
it++;
nX1 = *it;
it++;
nY2 = *it;
it++;
nX2 = *it;
it++;
nDistance += sqrt(((nX2 - nX1) * (nX2 - nX1)) +
((nY2 - nY1) * (nY2 - nY1)));
if (nDistance > nMidPoint)
nY2 = nY1 + ((nY2 - nY1) / 2);
nX2 = nX1 + ((nX2 - nX1) / 2);
break;
nY1 = nY2;
nX1 = nX2;
pMidPoint.push_back(nY2);
pMidPoint.push_back(nX2);
return pMidPoint;
catch(...)
double CSimpleGeometry::GetDistance(vector< float>* pPoints)
try
nDistance = 0.0f;
int j = 0;
long nSize = pPoints->size();
if (j == 0)
nY1 = *it;
it++;
nX1 = *it;
it++;
nY2 = *it;
it++;
nX2 = *it;
it++;
nY1 = nY2;
nX1 = nX2;
return nDistance;
catch(...)
There you go, you can use these functions to find the center point of an
n-gon and much more...
Martin Chapman
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Monday, April 05, 2004 1:35 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Center of polygon
Clay, Bruce wrote:
> Is there a method within OGR to find the center of a polygon (where it
> is not part of the data set) or polyline for the purposes of centering
> a label? If not does anyone have a method they are willing to share
> to walk through the data of a polygon / ring to determine the center?
Bruce,
There is no support this currently in GDAL/OGR. You might find
something like this in the general GEOS geometry engine. There is also
some centroid code in Shapelibs contrib directory if you would like to
adapt that.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
