[Gdal-dev] Center of polygon
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 6 12:19:29 EDT 2004
Clay, Bruce wrote:
> Daniel:
> Thanks for the tip. All I had to do is include the mitab_geometry.h
> file and the method did what I needed.
> Frank: Several of the methods in this file seem to be quite generic.
> Could / should they be moved to the public ORG API. So far I have only
> used OGRPolygonLabelPoint on polygons but I will be trying it on
> polylines this afternoon.
Bruce,
You are right that some of these methods could/should sensibly be moved up
to the OGRGeometry classes. However, I have been hesitant to start implementing
and document custom OGR implementations of these sorts of utility geometry
functions when I anticipate integration with GEOS to fill most of this
capability at some point.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
