[Gdal-dev] Question about gdal_translate (NITF export)
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 16 01:27:39 EDT 2004
Dinardo, George wrote:
> We have started to use the gdal_translate utility as delivered through
> OPENEV. We want to convert georeferenced SAR imagery data (CEOS) to NITF
> format, but are experiencing some problems. GeoTiff works well. Are there
> examples or help on which options we need to create an NITF format file.
George,
What pixel type is the CEOS data? I don't know that I have ever tested
producing complex (as in real+imaginary) NITF files with GDAL so I wouldn't
be surprised if that caused problems. Also, I believe GDAL will currently only
produce output files with nice affine geotransforms. If you are working with
un-rectified CEOS SAR data you will likely not be able to export the
georeferencing properly to NITF with the existing GDAL NITF driver.
I notice that the NITF driver does *not* report the full set of creation
options available. In effect many of the "metadata" header fields can be set
via creation options. I believe all the lines shown below using the "OVR"
macro can be set via creation options.
PLACE (achHeader+ 0, FDHR_FVER, "NITF02.10" );
OVR( 2,achHeader+ 9, CLEVEL, "05" );
PLACE (achHeader+ 11, STYPE ,"BF01" );
OVR(10,achHeader+ 15, OSTAID ,"GDAL" );
OVR(14,achHeader+ 25, FDT ,"20021216151629" );
OVR(80,achHeader+ 39, FTITLE ,"" );
OVR( 1,achHeader+119, FSCLAS ,"U" );
OVR( 2,achHeader+120, FSCLSY ,"" );
OVR(11,achHeader+122, FSCODE ,"" );
OVR( 2,achHeader+133, FSCTLH ,"" );
OVR(20,achHeader+135, FSREL ,"" );
OVR( 2,achHeader+155, FSDCTP ,"" );
OVR( 8,achHeader+157, FSDCDT ,"" );
OVR( 4,achHeader+165, FSDCXM ,"" );
OVR( 1,achHeader+169, FSDG ,"" );
OVR( 8,achHeader+170, FSDGDT ,"" );
OVR(43,achHeader+178, FSCLTX ,"" );
OVR( 1,achHeader+221, FSCATP ,"" );
OVR(40,achHeader+222, FSCAUT ,"" );
OVR( 1,achHeader+262, FSCRSN ,"" );
OVR( 8,achHeader+263, FSSRDT ,"" );
OVR(15,achHeader+271, FSCTLN ,"" );
OVR( 5,achHeader+286, FSCOP ,"00000" );
OVR( 5,achHeader+291, FSCPYS ,"00000" );
PLACE (achHeader+296, ENCRYP ,"0" );
achHeader[297] = achHeader[298] = achHeader[299] = 0x00; /* FBKGC */
OVR(24,achHeader+300, ONAME ,"" );
OVR(18,achHeader+324, OPHONE ,"" );
PLACE (achHeader+342, FL ,"????????????" );
PLACE (achHeader+354, HL ,"000404" );
PLACE (achHeader+360, NUMI ,"001" );
PLACE (achHeader+363, LISH1 ,"??????" );
PLACE (achHeader+369, LI1 ,CPLSPrintf("%010d",nImageSize) );
PLACE (achHeader+379, NUMS ,"000" );
PLACE (achHeader+382, NUMX ,"000" );
PLACE (achHeader+385, NUMT ,"000" );
PLACE (achHeader+388, NUMDES ,"000" );
PLACE (achHeader+391, NUMRES ,"000" );
PLACE (achHeader+394, UDHDL ,"00000" );
PLACE (achHeader+399, XHDL ,"00000" );
/* Prepare the image header. */
pachIMHDR = achHeader + 404;
PLACE (pachIMHDR+ 0, IM , "IM" );
OVR(10,pachIMHDR+ 2, HD1 , "Missing" );
OVR(14,pachIMHDR+ 12, IDATIM , "20021216151629" );
OVR(17,pachIMHDR+ 26, TGTID , "" );
OVR(80,pachIMHDR+ 43, IID2 , "" );
OVR( 1,pachIMHDR+123, ISCLAS , "U" );
OVR( 2,pachIMHDR+124, ISCLSY , "" );
OVR(11,pachIMHDR+126, ISCODE , "" );
OVR( 2,pachIMHDR+137, ISCTLH , "" );
OVR(20,pachIMHDR+139, ISREL , "" );
OVR( 2,pachIMHDR+159, ISDCTP , "" );
OVR( 8,pachIMHDR+161, ISDCDT , "" );
OVR( 4,pachIMHDR+169, ISDCXM , "" );
OVR( 1,pachIMHDR+173, ISDG , "" );
OVR( 8,pachIMHDR+174, ISDGDT , "" );
OVR(43,pachIMHDR+182, ISCLTX , "" );
OVR( 1,pachIMHDR+225, ISCATP , "" );
OVR(40,pachIMHDR+226, ISCAUT , "" );
OVR( 1,pachIMHDR+266, ISCRSN , "" );
OVR( 8,pachIMHDR+267, ISSRDT , "" );
OVR(15,pachIMHDR+275, ISCTLN , "" );
PLACE (pachIMHDR+290, ENCRYP , "0" );
OVR(42,pachIMHDR+291, ISORCE , "Unknown" );
PLACE (pachIMHDR+333, NROWS , CPLSPrintf("%08d", nLines) );
PLACE (pachIMHDR+341, NCOLS , CPLSPrintf("%08d", nPixels) );
PLACE (pachIMHDR+349, PVTYPE , pszPVType );
PLACE (pachIMHDR+352, IREP , pszIREP );
OVR( 8,pachIMHDR+360, ICAT , "VIS" );
OVR( 2,pachIMHDR+368, ABPP , CPLSPrintf("%02d",nBitsPerSample) );
OVR( 1,pachIMHDR+370, PJUST , "R" );
OVR( 1,pachIMHDR+371, ICORDS , " " );
The name (as per the NITF specs) to set the options are the third column
above. For instance, to set ONAME and OPHONE you might do:
gdal_translate -co "ONAME=Frank Warmerdam" -co OPHONE=9057800450 in.tif out.ntf
Do you have a sample input file you would like to be able to translate?
What problems are you seeing with the output file. I would be willing to
make some improvements to the GDAL NITF writing support if you need it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
