[Gdal-dev] Python Module Build
Fri Apr 16 15:04:57 EDT 2004
Alessandro Amici wrote:
> Sean,
> On Friday 16 April 2004 18:04, Sean Fulton wrote:
>>By the way, are there any test scripts for GDAL to make sure everything
>>is indeed working properly?
> not that i know of.
> Frank? do you have any testing toolkit?
Sean / Alessandro,
Yes, there is a test suite for GDAL.  If you check osrs/gdalautotest out
of the remotesensing.org CVS server, cd into it and run "run_test.py" an
extensive but far from comprehensive test suite will be run.  This depends
on having the GDAL python support working smoothly.
Best regards,
