[Gdal-dev] Irregular geolocation grid
Fri Apr 16 17:28:13 EDT 2004
Eric Dönges wrote:
> A (possibly dumb) question: can the "polynomial transformation stuff"
> you refer
> to above be used to map raster coordintes (pixels) to geographic
> coordinates ?
> Reading the supplied documentation has lead me to believe that if the
> mapping cannot
> be expressed in terms of an affine transform (which they can't in my
> case), the
> application is responsible for deriving a useable transform from the
> GCPs supplied
> by the dataset. Is this not the case ?
Eric,
The existing polynomial transform code (in gdal/alg) can be used to
derive a 1st, 2nd or 3rd order transformation based on the GCPs.  This
can then be used to translate back and forth between pixel/line and
whatever coordinate system is in use (usually lat/long).
However, keep in mind that a polynomial transformation does not necessarily
map the underlying relationship all that well.  All we really know is that
how to transform the points at the GCPs.
> On a somewhat related note, is there any reason (besides the rather ugly
> math involved)
> that GDALGCPsToGeoTransform() does not use all the GCPs available to
> determine an affine
> transform ? I've written a least squares approximation that takes all
> GCPs into account
> and thus does a somewhat better job (IMO, of course =8^) then the
> algorithm currently
> used that I'd like to contribute if there is any interest for it.
It was my intention that GDALGCPstoGeoTransform() would be corrected
to do a first order best fit approximation based on all the GCPs at some
point.  If you have a reasonly clean implementation of this feel free to
provide it.
Best regards,
