[Gdal-dev] Re: Transforming shapefiles from euref89 to ed50
Jakob Simon-Gaarde/Trapsoft Inc Jakobs at trapezesoftware.com
Wed Apr 21 01:53:08 EDT 2004
Thanks - It helped move the coordinates into the right area, but there is
still something wrong - here is what I am doing:
>>> import osr
>>> f=open('euref89_32n.wkt')
>>> euref = f.read()
>>> euref=euref.replace('\n','')
>>> f.close()
>>> f=open('ed50_32n.wkt')
>>> ed50=f.read()
>>> ed50=ed50.replace('\n','')
>>> sr_euref = osr.SpatialReference()
>>> sr_euref.ImportFromESRI([euref])
0
>>> sr_ed50=osr.SpatialReference()
>>> sr_ed50.ImportFromESRI([ed50])
0
>>> t=osr.CoordinateTransformation(sr_euref,sr_ed50)
>>> t.TransformPoint(560728.35341,6079776.68768)
(560731.3203323764, 6079908.6868730783, 0.0)
should have been
(560728.35341 ; 6079776.68768) -> (560808.942 ; 6079982.529)
Any ideas??
By the way isn't there a collection of wkt-files somewhere that are
garanteed correct?
by the way the unnamed tool is ESRI MapObjects based.
Med venlig hilsen / Best regards
Jakob Simon-Gaarde
Trapeze Software Europe A/S
Tlf. 87 44 16 00
Jakob Simon-Gaarde/Trapsoft Inc wrote:
> ogr2ogr -s_srs euref89_32n.wkt -t_srs ed50_32n.wkt out.shp stops_ll.shp
> where euref89_32n.wkt contains:
> PROJCS["ETRF_1989_UTM_Zone_32N",
>     GEOGCS["EUREF89_32N",
>         DATUM["ETRF_1989",
>             SPHEROID["WGS_1984",6378137.0,298.257223563]],
>         PRIMEM["Greenwich",9.0],
>         UNIT["Degree",0.0174532925199433]],
> and ed5089_32n.wkt contains:
> PROJCS["ED_1950_UTM_Zone_32N",
>     GEOGCS["GCS_European_1950",
>         DATUM["European_1950",
>             SPHEROID["International_1924",6378388,297]],
>         PRIMEM["Greenwich",0],
> What am I doing wrong - is it the wkt-files? I got those from two
> shapefiles with the projections I need.
Jacob,
I believe the problem is that you are indicating a prime meridian
of "Greenwich" at 9 degrees east of greenwich in the euref89 .wkt file.
I suspect the unnamed commerical software is ignoring the prime meridian
while OGR is trying to take it into account.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
