[Gdal-dev] no data column after gdal_translate
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 23 17:34:10 EDT 2004
Shoaib Burq (VPAC) wrote:
> Hi,
> I'm trying to convert some lidar data tiles in ArcGrid Bin frmt to
> geotiff. Each tile is georefereneced and is around 2mb in size.
> After converting using:
> "gdal_translate -ot float32 -of GTiff g1m3086000lh/hdr.adf
> g1m3086000lh.tiff'
> I view the image in ENVI and notice a column of pixels at the left edge of
> the image with the data value of '***************'
> The source data has fairly typical values along the edge. Plus this is
> happening for all the data tiles so it's probably not an issue with the
> source data.
> Has anyone come across this or know what could be causing it?
Shoaib,
I can't think of any obvious reason this would be happening. Can you provide
me one sample tile privately so I can try to reproduce the problem?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
