[Gdal-dev] Mrs ID driver for VC7
Chapman, Martin MChapman at sanz.com
Mon Apr 26 13:01:23 EDT 2004
Bjoern,
I called LizardTech and asked a sales rep for a copy.  He had me sign a license agreement and fax it back to him.  Apparently, Los Alamos requires them to keep a strict record on who licenses the sdk.  You will need to call them or send them an email.  Then they will send you a link to an ftp site where you can download the driver.
Martin
-----Original Message-----
Sent: Monday, April 26, 2004 10:39 AM
To: gdal-dev at remotesensing.org
Subject: AW: [Gdal-dev] Mrs ID driver for VC7
Hello Martin,
could you tell me how you got the MrSid DSDK 4.0 trial version? I could not find it on Lizardtech's homepage.
Thanks, Bjoern
> -----Ursprüngliche Nachricht-----
> Von: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org] Im Auftrag von
> Chapman, Martin
> Gesendet: Freitag, 23. April 2004 09:53
> An: gdal-dev at remotesensing.org; gdal-dev at remotesensing.org
> Betreff: RE: [Gdal-dev] Mrs ID driver for VC7
> Andrey,
> Thanks for the response.  I finally figured out how to link
> to mrsid, and thanks to the code update provided by Bjoern
> everything built ok.  Now I am getting the error "not
> recognized as a supported file format".  So I need to know
> where to set that option.
> Thanks,
> Martin
> 	From: Andrey Kiselev [mailto:dron at ak4719.spb.edu]
> 	Sent: Fri 4/23/2004 12:30 AM
> 	Cc:
> 	Subject: Re: [Gdal-dev] Mrs ID driver for VC7
> 	On Thu, Apr 22, 2004 at 04:14:28PM -0600, Chapman, Martin wrote:
> 	> I have a thirty day trial of the Mrs. Id driver for
> windows VC++
> 	> Version 7.  How do I link it to the GDAL lib?  Are
> there instructions
> 	> somewhere on how to do this?  I also read on the user
> group that there
> 	> may be issues with the V7 driver from Lizardtech and
> GDAL because GDAL
> 	> was written to bind to the VC6 version of the mrsid
> lib.  Is this an
> 	> issue?
> 	It is all the same for GDAL what compiler version will
> be used, bacause
> 	GDAL comes with full source code. It is completely
> defined by the DSDK
> 	binaries you have which you can't rebuild. The main
> problem is in API
> 	version. GDAL currently supports MrSID DSDK 3.1.x and
> 3.2.x. Newest
> 	version (4.0) are not supported yet due to completely
> different API.
> 	> I am using GDAL 1.1.9.
> 	There are was few fixes in that driver in GDAL 1.2.0.
> 	                                                Andrey
> 	Andrey V. Kiselev
> 	Home phone:  +7 812 5274898  ICQ# 26871517
> 	_______________________________________________
> 	Gdal-dev mailing list
> 	Gdal-dev at remotesensing.org
> 	http://remotesensing.org/mailman/listinfo/gdal-dev
Gdal-dev at remotesensing.org http://remotesensing.org/mailman/listinfo/gdal-dev
