[Gdal-dev] GeoJP2K: Unable to view 16-bit data
Valentine Anantharaj
val at GRI.MsState.Edu
Fri Apr 30 15:12:14 EDT 2004
Greetings!
I am unable to view some16-bit GeoJP2K files, created using GDAL w/
Kakadu support. The viewer window was simply blcak. I tried them using
both 'kdu_show' and the MSI viewer as well as their ArcView plug-ins. I
also got similar results (everything just black) from the '16-bit
comparison' samples from:
ftp://ftp.remotesensing.org/jpeg2000/16bitcomparison
The 8-bit, 3 channel RGB files display fine in both kdu_show and MSI
viewer. Any recommendation for viewing 16-bit GeoJP2K files? I do not
have the necessary patches/sevice-packs/modules for ENVI 4.0 or IMAGINE 8.6.
Thanks.
Regards,
VGA
