FW: [Gdal-dev] VC proj files?
Ben Discoe
ben at vterrain.org
Tue Aug 3 17:02:19 EDT 2004
I meant this to go the list, in case anyone else is interested.
-Ben
Sent: Tuesday, August 03, 2004 4:16 PM
To: 'David Schulze'
David,
This is a recurring subject on the GDAL list. You can search the list
archive to follow the discussion, or i can save you the effort and simply
point to:
http://vterrain.org/dist/gdal_vc7.zip
Be advised these .sln/.vcproj files are not part of the core GDAL, and not
maintained by the GDAL folks, so they are not supported nor necessarily kept
up to date.
Personally, i find it much more useful to build GDAL in an IDE which lets me
browse through the source with a click or two, and switch between debug and
release builds without editing any files.
-Ben
Sent: Tuesday, August 03, 2004 11:39 AM
Does anyone have VC.NET 2003 project files for GDAL? Make files are a
nightmare. I've contemplated trying to create a project file myself, but I
figured if someone had already done it and was nice enough to share, that
I'd take advantage of that.
Thanks
David Schulze
DeLorme Mapping
Yarmouth, ME, USA
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040803/3e2d6cb9/attachment.html
