[Gdal-dev] Re: [GRASSLIST:4082] BSQ import question
Andrey Kiselev dron at ak4719.spb.edu
Sat Aug 7 15:57:39 EDT 2004
On Wed, Aug 04, 2004 at 06:11:35PM +0200, Markus Neteler wrote:
> The global land cover file is at:
>  ftp://ftp.glcf.umiacs.umd.edu/glcf/Global_Land_Cover/Global/gl-latlong-1km-landcover/
>  Information
>  Image Size: 				43200 Pixels 21600 Lines
>  Quantization:			    8-bit unsigned integer
>  Output Georeferenced Units: LONG/LAT E019
>  Projection:    				Geographic (geodetic)
>  Earth Ellipsoid:			Sphere, rad 6370997 m
>  Upper Left Corner:			180d00'00.00" W Lon90d00'00.00" N Lat
>  Lower Right Corner:			180d00'00.00" E Lon 90d00'00.00" S Lat
>  Pixel Size (in Degrees):	0.00833 Lon 0.00833 Lat
>  (Equivalent Deg,Min,Sec):	0d00'30.00"0d00'30.00"
>  UpLeftX:					-180
>  UpLeftY:      				90
>  LoRightX:        			180
>  LoRightY:      				-90
> -> note the Sphere!
> This is relevant for the definition of the location.
> See 'gl-latlong-1km-landcover.grasslocation.txt' attachment for details.
> > Some of you are probably familiar with this.  Assuming this, I
> > have a few questions from GRASS 5.3.
> > Any ideas?  Has anyone worked with this data set?  I'm running this on
> > a linux box, if it matters.
> Use r.in.gdal instead. It's way easier. You just have to generate
> a BSQ ENVI header file, then import the map (find attached the file).
> I hope I got that file right, following
>  http://glcf.umiacs.umd.edu/data/guide/fileformat/bsq.shtml
>  => RSI ENVI 3.6
>     However, I didn't set bands = 14 but bands = 1
> Now check with 'gdalinfo':
> gdalinfo -mm gl-latlong-1km-landcover.bsq
> Driver: ENVI/ENVI .hdr Labelled
> Size is 43200, 21600
> Coordinate System is:
> LOCAL_CS["Geographic Lat/Lon",
>     UNIT["Meter",1]]
> Origin = (-180.000000,90.000000)
> Pixel Size = (0.00833333,-0.00833333)
> Corner Coordinates:
> Upper Left  (-180.0000000,  90.0000000)
> Lower Left  (-180.0000000, -90.0000000)
> Upper Right ( 180.0000000,  90.0000000)
> Lower Right ( 180.0000000, -90.0000000)
> Center      (  -0.0000000,   0.0000000)
> Band 1 Block=43200x1 Type=Byte, ColorInterp=Undefined
>     Computed Min/Max=0.000,13.000
> IMHO the projection is not detected completely by GDAL,
> or should it be LOCAL_CS?
Markus,
I can't reproduce your result. I have the following with your .hdr file:
$ gdalinfo gl-latlong-1km-landcover.bsq
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AXIS["Lat",NORTH],
    AXIS["Long",EAST],
    AUTHORITY["EPSG","4326"]]
Corner Coordinates:
Upper Left  (-180.0000000,  90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
Lower Left  (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
Upper Right ( 180.0000000,  90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
Center      (  -0.0000000,   0.0000000) (  0d 0'0.00"W,  0d 0'0.00"N)
  Description = Band 1
Are you using the latest CVS snapshot?
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
