[Gdal-dev] ./configure setting GEOS_INC without -I
Vincent Schut
schut at sarvision.com
Mon Aug 9 04:20:07 EDT 2004
Dear dev's,
when using the --with-geos switch, GEOS_INC in GDALmake.opt is set to
'/usr/local/include'. At which my gcc segfaults because it can't find the
file /usr/local/include... This can of course be fixed by adding '-I' before
the '/usr/local/inclue'.
Btw, I suppose gdal's geos support is based on geos-1.0, not on current cvs
(as they are changing API...)?
Vincent Schut
SarVision B.V.
Wageningen, The Netherlands
www.sarvision.com
