[Gdal-dev] ogrtindex - mapserver
bartvde at xs4all.nl bartvde at xs4all.nl
Tue Aug 10 02:09:05 EDT 2004
Hi list,
I am using ogrtindex in conjunction with Mapserver and ran into a problem.
Ogrtindex writes e.g. the following in the location attribute:
location
d:\data\myshape.shp,0
etc.
This way Mapserver won't find the quadtree index file (qix) associated
with the shapefile (as it will look for d:\data\myshape.shp,0.qix).
I have to edit the tile-index and change it into:
location
d:\data\myshape
etc.
in order to have Mapserver use the quadtree index for the data shapefiles
(note d:\data\myshape.shp does not work either).
Is there an option in ogrtindex which I am missing?
Best regards,
Bart
