[Gdal-dev] Reprojection
jirifranc at centrum.cz jirifranc at centrum.cz
Tue Aug 3 08:31:56 EDT 2004
  Hello,
example:
I have one old.shp file in 28404 projection and I have *.map file,
where I m using 28403 global projection. I want to use ogr2ogr file
to change projection of old.shp file from 28404 to 28403, but with the
same *.shp file name.
I need only change projection in old.shp (with ogr2ogr utility),
nothing more........
Which order I must write to do this?
Thank you.
Leto a sport bez zabran s jednodennimi cockami Focus Dailies! Hrajte letní
SMS hru o pulrocni zasobu cocek Focus Dailies! Více na http://user.centrum.cz/redir.php?url=http://www.cz.cibavision.com
