[Gdal-dev] Re: GDAL and Spot Vegetation
Norman Vine
nhv at cape.com
Wed Aug 18 12:28:35 EDT 2004
Vincent Schut writes:
> About Plate Caree, I'm not sure either. I used a simple lat/long wgs84
> configuration which looked OK. It is however possible that better projection
> parameters exist...
"Plate Caree" is just another name for "Equidistant Cylindrical" Projection
i.e. linear scaling of latitudes and longitudes
In other words, all meridians and parallels are straight lines.
HTH
Norman
