[Gdal-dev] OGRSpatialReference WKS question
Chapman, Martin
MChapman at sanz.com
Thu Aug 26 12:44:43 EDT 2004
Given the well known string for a spatial reference, what is the OGR
syntax that will always return the expected node? For example, what is
the syntax that will always return all the GEOGCS|AXIS nodes for the
following WKS?
PROJCS
<http://geoapi.sourceforge.net/snapshot/javadoc/org/opengis/referencing/
doc-files/WKT.html#PROJCS> ["OSGB 1936 / British National Grid",
GEOGCS
doc-files/WKT.html#GEOGCS> ["OSGB 1936",
DATUM
doc-files/WKT.html#DATUM> ["OSGB_1936",
SPHEROID
doc-files/WKT.html#SPHEROID> ["Airy
1830",6377563.396,299.3249646,AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","7001"]],
TOWGS84
doc-files/WKT.html#TOWGS84> [375,-111,431,0,0,0,0],
AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","6277"]],
PRIMEM
doc-files/WKT.html#PRIMEM> ["Greenwich",0,AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","8901"]],
UNIT
doc-files/WKT.html#UNIT> ["DMSH",0.0174532925199433,AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","9108"]],
AXIS
doc-files/WKT.html#AXIS> ["Lat",NORTH],
AXIS
doc-files/WKT.html#AXIS> ["Long",EAST],
AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","4277"]],
PROJECTION
doc-files/WKT.html#PROJECTION> ["Transverse_Mercator"],
PARAMETER
doc-files/WKT.html#PARAMETER> ["latitude_of_origin",49],
PARAMETER
doc-files/WKT.html#PARAMETER> ["central_meridian",-2],
PARAMETER
doc-files/WKT.html#PARAMETER> ["scale_factor",0.999601272],
PARAMETER
doc-files/WKT.html#PARAMETER> ["false_easting",400000],
PARAMETER
doc-files/WKT.html#PARAMETER> ["false_northing",-100000],
UNIT
doc-files/WKT.html#UNIT> ["metre",1,AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","9001"]],
AXIS
doc-files/WKT.html#AXIS> ["E",EAST],
AXIS
doc-files/WKT.html#AXIS> ["N",NORTH],
AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","27700"]],
VERT_CS
doc-files/WKT.html#VERT_CS> ["Newlyn",
VERT_DATUM
doc-files/WKT.html#VERT_DATUM> ["Ordnance Datum Newlyn",2005,AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","5101"]],
UNIT
AXIS
doc-files/WKT.html#AXIS> ["Up",UP],
AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","5701"]],
AUTHORITY
doc-files/WKT.html#AUTHORITY> ["EPSG","7405"]]
I know I can use something like
OGRSpatialReference->GetAttrValue("UNIT", 0), but that will only return
the first UNIT child node depending on where the root is. Does anyone
have this worked out. Code would be much appreciated.
Thanks,
Martin Chapman
Cell 303-885-1936
Office 303-495-6300 x326
mchapman at sanz.com
http://www.sanz.com <http://www.sanz.com/>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040826/0351d326/attachment.html
