[Gdal-dev] Help with gdal_merge errors
Julia.Harrell at ncmail.net
Wed Dec 1 13:20:07 EST 2004
Hi GDAL Listers,
I'm trying to use the gdal_merge distributed with the Windows binary of
OpenEv_FW_182 to merge a large number of tiled JPEGs with this command line
(most of the filenames were omitted for this example).
C:\OpenEV_FW\python\python.exe C:\OpenEV_FW\pymod\gdal_merge.py -o Y:\isa03jpgm\camd_isa03_83m.jpg
and I am getting this error message:
'import site' failed; use -v for traceback
ERROR 6: GDALDriver::Create() ... no create method implemented for this format.
File "C:\OpenEV_FW\pymod\gdal_merge.py", line 412, in ?
t_fh.SetGeoTransform( geotransform )
AttributeError: 'NoneType' object has no attribute 'SetGeoTransform'
Can someone offer a solution? I'm not well versed enough yet in Python to
figure out (or fix) the error referenced on line 412.
Also, I have PYTHONHOME and OPENEV_DIR env vars set, and added everything
conceivable to my path, but could not get the gdal_merge.bat file to run.
The error I get is "'python' is not recognized as an internal or external
command, operable program or batch file." - so that's why I'm explictly
calling the python exe and the gdal_merge script. There's got to be a better
way, I just don't know what it is yet. Some advice there would also be
appreciated.
Thanks for the help,
Julia Harrell
NC DENR
