[Gdal-dev] HDF Georeference
Carl Anderson
carl.anderson at vadose.org
Thu Dec 2 20:41:53 EST 2004
On 12/02/2004 07:16:01 AM, wlx wrote:
> Hi all,
> In the hdf4 format
> homepage(http://www.remotesensing.org/gdal/frmt_hdf4.html),it is
> sayed
> that
> gdal can support ASTER L1B data's georeference.
> When I use gdal_translate utility to translate a ASTER's
> subdataset to a
> geotiff file,I find the geotiff file include nothing about
> georefence.
I do know that the HDF driver has been redone and works differently
in recent GDAL versions
the old driver was
HDF4_SDS:ASTER_L1B:
checking with gdalinfo recent GDAL version
HDF4_EOS:EOS_SWATH:
is the driver for ASTER L1B file
revert back to
OpenEV_FW 1.7.2 (which ises the HDF4_SDS dirver)
or download HEG from
http://eosweb.larc.nasa.gov/PRODOCS/misr/tools/geotiff_tool.html
and run HEG on the HDF to produce georegistered bands as tiffs.
I have not had an opportunity to compare the results of HEGtools and
the older HDF_SDS driver.
If you get a chance to compare them
is there any pixel shift between the two methods or are they
functionally equivalent.
C.
carl anderson
GIS Manager
Fulton County Georgia
