[Gdal-dev] ESRI SDI format
Frank Warmerdam fwarmerdam at gmail.com
Fri Dec 3 11:39:45 EST 2004
On Fri, 3 Dec 2004 09:39:34 -0500, Baranovsky, Eduard
<ebaranovsky at roadware.com> wrote:
> Does OGR support ESRI SDI format?
Eduard,
I assume hyou mean ESRI SDE datastores?  The short answer
is no, but it does look like I will be implementing at least SDE vector
read support in the next few months.  The the more complex answer
is, perhaps to some degree, soon.
Best regards,
