[Gdal-dev] GDAL on WinCE?
Alain Rist
ar at navpoch.com
Wed Dec 8 12:43:55 EST 2004
Franck,
WinCE systems are Unicode only.
You can process char, char*, char& and char[] types as usual, but any string transfer with the system ( file names, error messages etc..) is Unicode.
Many places in GDAL code embed such strings. All these char* or char[] should be changed to TCHAR ( a macro that expands to wchar_t if Unicode is enabled ) , without touching the real char type used in the formats.
By the way, Unicode enabling GDAL is a very good idea : if coupled with grouping of all message strings and hard-coded names in some resource location, it would open the possibility for non english speakers to use GDAL !
But if it is on your TODO list, I am afraid it gets a very bad scoring.
Thanks for all anyway.
Alain
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041208/b007c99b/attachment.html
