[Gdal-dev] JP2 geo info question
Frank Warmerdam fwarmerdam at gmail.com
Thu Dec 9 17:04:59 EST 2004
On Thu, 9 Dec 2004 15:58:58 -0600, Simpson <asimpson at i-55.com> wrote:
> Frank,
> j2w works!  I tried jpw and tfw, but not the j2w.
> I now have maps rendering from mapserver with these re-encoded jp2s, and no
> 'assertion failed' crashes.
Cool!   Though you shouldn't have run into all the problems you did.
> I re-encoded lossless and only 4 overviews, whereas the originals were lossy
> with 11 overviews.  I'll try with more overviews to see if it'll crash.
> How would one set the coordinate system? Via API and GeoTiff?
The -a_srs switch on the gdal_translate commandline can be used to
assign a coordinate system.  It takes a variety of formats to describe
the coordinate system including PROJ.4 and EPSG codes.
eg.
gdal_translate -a_srs EPSG:4326 in.tif out.tif
or
gdal_translate -a_srs '+proj=utm +zone=11 +datum=WGS84' in.tif out.tif
Best regards,
