[Gdal-dev] how to read SRTM files
Thom DeCarlo
t.r.decarlo at LARC.NASA.GOV
Mon Dec 13 16:07:47 EST 2004
Eduardo,
This question has come up quite a few times in several lists I'm on. (I
asked once, myself.)
First, if you are using a Linux computer or can install Cygwin (from
www.cygwin.org) on your Windows computer you can use this bash script that I
modified from Markus Neteler's website:
http://mpa.itc.it/rs/srtm/
This shell program will change the name of the .hgt to .bil. It then
generates the .hdr and .prj files for the ESRI file reader. Finally, it
launches gdal_translate to build a geotiff from the bil file.
HTH,
Thom
Thom DeCarlo
Do Not Meddle in the Affairs of Dragons
For You are Crunchy and Taste Good with Ketchup
> -----Original Message-----
> From: Eduardo Patto Kanegae
> Sent: Monday, December 13, 2004 1:42 PM
> To: gdal-dev
> Subject: [Gdal-dev] how to read SRTM files
> Hi folks,
> I'm downloading SRTM NASA ziped files from
> ftp://e0dps01u.ecs.nasa.gov/srtm/South_America/ but I saw that I don't
> know this file format(.hgt)
> runnig "gdalinfo" one .hgt file I only got:
> ERROR 4: `N01W050.hgt' not recognised as a supported file format.
> GDALOpen failed - 4
> Or my GDAL tools is missing something?
> Is there any free software that can read this files?
> thanks
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041213/ae4521c0/srtm3_generate_geotiff.obj
