[Gdal-dev] Compile error on 1.2.5
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Tue Dec 21 16:41:50 EST 2004
> Kralidis,Tom [Burlington] wrote:
> > # ogrinfo
> > ogrinfo: error while loading shared libraries: libxerces-c.so.26:
> > cannot open shared object file: No such file or directory
> > Yet, this file is present:
> > # ls -l /usr/local/lib/libxerces-c.so.26
> > lrwxrwxrwx  1 root root 19 Dec 21 14:32
> > -> libxerces-c.so.26.0
> Is this a new version of libxerces-c.so.26 that you just
> installed? You
> may need to run /sbin/ldconfig to update the runtime lib cache. (Also
> make sure /usr/local/bin is in the /etc/ld.so.conf before you run it.)
Yup, this worked.  Thanks.  I assumed (you know what happens when you
assume) that /sbin/ldconfig only gets run when a new entry is made in
/etc/ld.so.conf.
At any rate, it works now.  When I peruse /usr/local/lib, I find this
hanging around:
-rwxr-xr-x   1 root root 3486188 Jun 16  2004 libgdal.so.1.2.0*
...which is from gdal-1.2.0b.  Is it safe to blow this away?
..Tom
