[Gdal-dev] Linux port problem
Jack Varga
jvarga at boulder.net
Wed Dec 22 19:21:00 EST 2004
Bruce,
It would be helpful if you included the command you are attempting to
execute, the stdout and stderr it is producing, your platform specifics,
(i.e., OS vender, kernel rev. & system architecture), and your compiler
(version).
You don't need root access to build gdal, just execute permission to the
compiler, (make tools, preprocessor), read access to shared libraries
and headers, and write access to some place (i.e., your home directory)
where you can compile (and ultimately execute) your binaries. However, I
am confused as to what you're trying to do. Are you attempting to link
GDAL to an application you wrote, or some other (perhaps common)
application? I'm also confused by your statement, "it kept looking for
SQL files."
Jack Varga
Clay, Bruce wrote:
> I am having problems porting my (working) Windows based application to
> Linux. It is most likely something I am doing wrong in the Makefile.
> Right up front I will admit I am very rusty on Linux. It has been
> several years since I have used it regularly and then I explicitly
> linked dot a files rather than dot so files.
> I first tried to build GDAL from the current tarball and did get
> libraries out of it but it kept looking for SQL files so I downloaded
> the FWTools-linux-0.9.4.tar.gz file. I do not have root access to the
> system so I unpacked the tar file and put all of the files from the
> lib directory in a directory in my LD_LIBRARY_PATH.
> I have libgdal.so in my makefile library path but I get several link
> (undefined reference) errors on various GDAL and OGR member functions
> such as GDALRasterBand::GetRasterDataType and OGRPoint::OGRPoint. I
> believe the linker is finding the library ok because if I take
> libgdal.so out of the make file I get eve more errors such as GDALOpen.
> As I recall we used to have to run ranlib on dot a files when they did
> this kind of thing but that doesn’t apply to dot so files does it?
> Besides that since I am using the precompiled libraries it seems like
> they should already be up to date.
> I know this is likely some dumb thing I am not doing but I don’t see what.
> Any thoughts would be greatly appreciated.
> Bruce
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at xserve.flids.com
>http://xserve.flids.com/mailman/listinfo/gdal-dev
