[Gdal-dev] Re: Gdal-dev digest, Vol 1 #398 - 2 msgs
Jeff D. Hamann
jeff.hamann at forestinformatics.com
Mon Feb 2 13:22:41 EST 2004
It worked like a charm....
Now if I could just get grass to build...
Thanks,
Jeff.
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Monday, February 02, 2004 9:00 AM
Subject: Gdal-dev digest, Vol 1 #398 - 2 msgs
> Send Gdal-dev mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://remotesensing.org/mailman/listinfo/gdal-dev
> or, via email, send a message with subject or body 'help' to
> gdal-dev-request at remotesensing.org
> You can reach the person managing the list at
> gdal-dev-admin at remotesensing.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Gdal-dev digest..."
> Today's Topics:
> 1. Re: latest in the hdf-gdal-grass hdf-eos saga.... (Andrey Kiselev)
> 2. Re: Re: undefined python objects (Christopher Fonnesbeck)
> --__--__--
> Message: 1
> From: Andrey Kiselev <dron at ak4719.spb.edu>
> Date: Sun, 1 Feb 2004 21:41:16 +0300
> To: gdal-dev at remotesensing.org, grass5 at grass.itc.it
> Subject: Re: [Gdal-dev] latest in the hdf-gdal-grass hdf-eos saga....
> Reply-To: gdal-dev at remotesensing.org
> On Sat, Jan 31, 2004 at 11:31:40AM -0800, Jeff D. Hamann wrote:
> > but after all that I still can't figure out how to make gdal-1.1.9.
> > All I get when I type ./configure (without the --with-hdf4 stuff even)
> > and make is:
> > config.status: creating port/cpl_config.h
> > $ make
> > make: no target to make.
> I'm agree with Alessandro, it is BSD make problem. Note, that makefile
> in the GDAL root called GNUmakefile. That's why you can't handle it with
> your make utility. Use gmake instead.
> > So this project will have to go into the drawer again until I can some
> > of th ese resolved... And after all that, does anyone actually if
> > GRASS can import ASTER L1B images?
> Yes.
> Andrey V. Kiselev
> Home phone: +7 812 5274898 ICQ# 26871517
> --__--__--
> Message: 2
> Cc: gdal-dev at remotesensing.org
> From: Christopher Fonnesbeck <chris at fonnesbeck.org>
> Subject: Re: [Gdal-dev] Re: undefined python objects
> Date: Sat, 31 Jan 2004 10:36:21 -0500
> To: Alessandro Amici <alexamici at fastwebnet.it>
> On Jan 31, 2004, at 5:19 AM, Alessandro Amici wrote:
> > the build of the gdal python module has always been fragile, and it
> > has became
> > a real hack since the libtool transition (my fault, admittedly). IMHO
> > the
> > only hope to get out of the current mess is to use the distutils
> > infrastructure, that hopefully will take care of the OSX problem as
> > well.
> > so i refreshed what looked like an abandoned setup.py in the top
> > directory.
> > current gdal cvs builds and installs fine on linux with:
> > $ python setup.py build
> > $ python setup.py install
> > it wuold be very helpfull if you could test it on OSX and report the
> > results.
> On my machine (running OSX 10.3), the latest GDAL CVS chokes on
> compiling mrsid support:
> /bin/sh ../../libtool --mode=compile g++ -Wall -O2 -I../../port
> -I../../gcore -I../../ogr -Iinternal/include
> -I../../frmts/gtiff/libgeotiff -D_REENTRANT -I../../port -c -o
> ../o/mrsiddataset.o mrsiddataset.cpp
> g++ -Wall -O2 -I../../port -I../../gcore -I../../ogr
> -Iinternal/include -I../../frmts/gtiff/libgeotiff -D_REENTRANT
> -I../../port -c mrsiddataset.cpp -fno-common -DPIC -o
> ../o/.libs/mrsiddataset.o
> mrsiddataset.cpp:51:26: lt_fileUtils.h: No such file or directory
> mrsiddataset.cpp:52:23: lt_xTrans.h: No such file or directory
> mrsiddataset.cpp:53:32: lt_imageBufferInfo.h: No such file or directory
> mrsiddataset.cpp:54:22: lt_pixel.h: No such file or directory
> mrsiddataset.cpp:55:27: lt_colorSpace.h: No such file or directory
> mrsiddataset.cpp:56:28: MrSIDImageFile.h: No such file or directory
> mrsiddataset.cpp:57:28: MrSIDNavigator.h: No such file or directory
> mrsiddataset.cpp:58:28: MetadataReader.h: No such file or directory
> mrsiddataset.cpp:59:29: MetadataElement.h: No such file or directory
> mrsiddataset.cpp:64: error: `LizardTech' was not declared in this scope
> mrsiddataset.cpp:66: warning: ISO C++ forbids declaration of
> `LT_USE_NAMESPACE'
> with no type
> mrsiddataset.cpp:66: error: syntax error before `static'
> mrsiddataset.cpp: In function `char* cvsid_aw()':
> mrsiddataset.cpp:66: error: `cpl_cvsid' undeclared (first use this
> function)
> mrsiddataset.cpp:66: error: (Each undeclared identifier is reported
> only once
> for each function it appears in.)
> mrsiddataset.cpp: At global scope:
> mrsiddataset.cpp:84: error: syntax error before `*' token
> mrsiddataset.cpp:85: error: syntax error before `*' token
> mrsiddataset.cpp:86: error: syntax error before `*' token
> mrsiddataset.cpp:87: error: syntax error before `*' token
> mrsiddataset.cpp:88: error: syntax error before `*' token
> mrsiddataset.cpp:90: error: syntax error before `::' token
> mrsiddataset.cpp:92: error: syntax error before `*' token
> mrsiddataset.cpp:105: error: parse error before `*' token
> mrsiddataset.cpp:130: error: syntax error before `*' token
> mrsiddataset.cpp:131: error: syntax error before `*' token
> mrsiddataset.cpp: In constructor `
> MrSIDRasterBand::MrSIDRasterBand(MrSIDDataset*, int)':
> mrsiddataset.cpp:164: error: 'class MrSIDDataset' has no member named '
> poMrSidNav'
> mrsiddataset.cpp:165: error: 'class MrSIDDataset' has no member named '
> poMrSidNav'
> mrsiddataset.cpp:165: error: `IntRect' undeclared (first use this
> function)
> mrsiddataset.cpp:165: error: parse error before `::' token
> mrsiddataset.cpp:167: error: `poImageBufInfo' undeclared (first use this
> function)
> mrsiddataset.cpp:167: error: parse error before `(' token
> mrsiddataset.cpp: In member function `virtual CPLErr
> MrSIDRasterBand::IRasterIO(GDALRWFlag, int, int, int, int, void*,
> int, int,
> GDALDataType, int, int)':
> mrsiddataset.cpp:216: error: `ImgRect' undeclared (first use this
> function)
> mrsiddataset.cpp:216: error: parse error before `(' token
> mrsiddataset.cpp:217: error: `IntDimension' undeclared (first use this
> function)
> mrsiddataset.cpp:220: error: 'class MrSIDDataset' has no member named '
> poMrSidNav'
> mrsiddataset.cpp:220: error: `imageSupport' undeclared (first use this
> function)
> mrsiddataset.cpp:220: error: `targetDims' undeclared (first use this
> function)
> mrsiddataset.cpp:228: error: `poImageBuf' undeclared (first use this
> function)
> mrsiddataset.cpp:228: error: parse error before `(' token
> mrsiddataset.cpp:231: error: 'class MrSIDDataset' has no member named '
> poMrSidNav'
> mrsiddataset.cpp:233: error: parse error before `oException'
> mrsiddataset.cpp:236: error: `oException' undeclared (first use this
> function)
> mrsiddataset.cpp:214: warning: unused variable `int iSrcOffset'
> mrsiddataset.cpp:214: warning: unused variable `int nNewYSize'
> mrsiddataset.cpp:214: warning: unused variable `int nNewXSize'
> mrsiddataset.cpp:213: warning: unused variable `int iLine'
> mrsiddataset.cpp:212: warning: unused variable `int nBufDataSize'
> mrsiddataset.cpp:240: warning: ISO C++ forbids declaration of
> `nNewXSize' with
> no type
> mrsiddataset.cpp:241: warning: ISO C++ forbids declaration of
> `nNewYSize' with
> no type
> mrsiddataset.cpp:242: warning: ISO C++ forbids declaration of
> `iSrcOffset' with
> no type
> mrsiddataset.cpp:242: error: `nBand' was not declared in this scope
> mrsiddataset.cpp:244: error: parse error before `for'
> mrsiddataset.cpp:244: error: `nBufYSize' was not declared in this scope
> mrsiddataset.cpp:244: error: parse error before `;' token
> mrsiddataset.cpp:244: error: syntax error before `++' token
> mrsiddataset.cpp:259: error: `nBufYSize' was not declared in this scope
> mrsiddataset.cpp:262: error: `iLine' was not declared in this scope
> mrsiddataset.cpp:265: error: parse error before `for'
> mrsiddataset.cpp:265: error: `nBufXSize' was not declared in this scope
> mrsiddataset.cpp:265: error: parse error before `;' token
> mrsiddataset.cpp:265: error: syntax error before `++' token
> MrSIDRasterBand::IReadBlock(int, int, void*)':
> mrsiddataset.cpp:292: error: parse error before `(' token
> mrsiddataset.cpp:293: error: 'class MrSIDDataset' has no member named '
> poMrSidNav'
> mrsiddataset.cpp:295: error: parse error before `::' token
> mrsiddataset.cpp:299: error: 'class MrSIDDataset' has no member named '
> poMrSidNav'
> mrsiddataset.cpp:301: error: parse error before `oException'
> mrsiddataset.cpp:290: warning: unused variable `int j'
> mrsiddataset.cpp:290: warning: unused variable `int i'
> mrsiddataset.cpp:308: error: parse error before `for'
> mrsiddataset.cpp:308: error: `nBlockSize' was not declared in this scope
> mrsiddataset.cpp:308: error: parse error before `;' token
> mrsiddataset.cpp:308: error: syntax error before `++' token
> mrsiddataset.cpp: In member function `virtual GDALColorInterp
> MrSIDRasterBand::GetColorInterpretation()':
> mrsiddataset.cpp:343: error: 'class MrSIDDataset' has no member named '
> poColorSpace'
> mrsiddataset.cpp:345: error: `ColorSpace' undeclared (first use this
> function)
> mrsiddataset.cpp:345: error: parse error before `::' token
> mrsiddataset.cpp:354: error: parse error before `::' token
> mrsiddataset.cpp:365: error: parse error before `::' token
> mrsiddataset.cpp:367: error: parse error before `::' token
> mrsiddataset.cpp: In constructor `MrSIDDataset::MrSIDDataset()':
> mrsiddataset.cpp:416: error: `poFilename' undeclared (first use this
> function)
> mrsiddataset.cpp:417: error: `poMrSidFile' undeclared (first use this
> function)
> mrsiddataset.cpp:418: error: `poMrSidNav' undeclared (first use this
> function)
> mrsiddataset.cpp:419: error: `poDefaultPixel' undeclared (first use this
> function)
> mrsiddataset.cpp:420: error: `poMrSidMetadata' undeclared (first use
> this
> function)
> mrsiddataset.cpp:421: error: `poColorSpace' undeclared (first use this
> function)
> mrsiddataset.cpp:423: error: `eSampleType' undeclared (first use this
> function)
> mrsiddataset.cpp:423: error: `ImageBufferInfo' undeclared (first use
> this
> function)
> mrsiddataset.cpp:423: error: parse error before `::' token
> mrsiddataset.cpp:502: error: parse error before `*' token
> mrsiddataset.cpp: In member function `char*
> MrSIDDataset::SerializeMetadataElement(...)':
> mrsiddataset.cpp:504: error: `IntDimension' undeclared (first use this
> function)
> mrsiddataset.cpp:504: error: parse error before `=' token
> mrsiddataset.cpp:509: error: `oDim' undeclared (first use this function)
> mrsiddataset.cpp:512: error: `poElem' undeclared (first use this
> function)
> mrsiddataset.cpp:514: error: `MetadataValue' undeclared (first use this
> function)
> mrsiddataset.cpp:514: error: parse error before `::' token
> mrsiddataset.cpp:519: error: parse error before `::' token
> mrsiddataset.cpp:524: error: parse error before `::' token
> mrsiddataset.cpp:527: error: parse error before `::' token
> mrsiddataset.cpp:530: error: parse error before `::' token
> mrsiddataset.cpp:518: warning: unreachable code at beginning of switch
> statement
> mrsiddataset.cpp: In member function `int
> MrSIDDataset::GetMetadataElement(const char*, void*)':
> mrsiddataset.cpp:558: error: `MetadataElement' undeclared (first use
> this
> function)
> mrsiddataset.cpp:559: error: parse error before `(' token
> mrsiddataset.cpp:562: error: parse error before `::' token
> mrsiddataset.cpp:567: error: parse error before `::' token
> mrsiddataset.cpp:570: error: `iValue' undeclared (first use this
> function)
> mrsiddataset.cpp:573: error: parse error before `::' token
> mrsiddataset.cpp:578: error: parse error before `break'
> mrsiddataset.cpp:582: error: `pValue' was not declared in this scope
> mrsiddataset.cpp:582: warning: ISO C++ forbids declaration of `memcpy'
> with no
> type
> mrsiddataset.cpp:582: error: `int memcpy' redeclared as different kind
> of
> symbol
> /usr/include/string.h:76: error: previous declaration of `void*
> memcpy(void*,
> const void*, long unsigned int)'
> mrsiddataset.cpp:582: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:583: error: parse error before `}' token
> mrsiddataset.cpp:588: error: `pValue' was not declared in this scope
> mrsiddataset.cpp:588: warning: ISO C++ forbids declaration of `memcpy'
> with no
> type
> mrsiddataset.cpp:588: error: redefinition of `int memcpy'
> mrsiddataset.cpp:582: error: `int memcpy' previously defined here
> mrsiddataset.cpp:588: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:589: error: parse error before `}' token
> mrsiddataset.cpp:594: error: `pValue' was not declared in this scope
> mrsiddataset.cpp:594: warning: ISO C++ forbids declaration of `memcpy'
> with no
> type
> mrsiddataset.cpp:594: error: redefinition of `int memcpy'
> mrsiddataset.cpp:588: error: `int memcpy' previously defined here
> mrsiddataset.cpp:594: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:595: error: parse error before `}' token
> mrsiddataset.cpp:600: error: `pValue' was not declared in this scope
> mrsiddataset.cpp:600: warning: ISO C++ forbids declaration of `memcpy'
> with no
> type
> mrsiddataset.cpp:600: error: redefinition of `int memcpy'
> mrsiddataset.cpp:594: error: `int memcpy' previously defined here
> mrsiddataset.cpp:600: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:601: error: parse error before `}' token
> mrsiddataset.cpp:606: error: `pValue' was not declared in this scope
> mrsiddataset.cpp:606: error: `fValue' was not declared in this scope
> mrsiddataset.cpp:606: warning: ISO C++ forbids declaration of `memcpy'
> with no
> type
> mrsiddataset.cpp:606: error: redefinition of `int memcpy'
> mrsiddataset.cpp:600: error: `int memcpy' previously defined here
> mrsiddataset.cpp:606: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:607: error: parse error before `}' token
> mrsiddataset.cpp:612: error: `pValue' was not declared in this scope
> mrsiddataset.cpp:612: error: `dfValue' was not declared in this scope
> mrsiddataset.cpp:612: warning: ISO C++ forbids declaration of `memcpy'
> with no
> type
> mrsiddataset.cpp:612: error: redefinition of `int memcpy'
> mrsiddataset.cpp:606: error: `int memcpy' previously defined here
> mrsiddataset.cpp:612: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:613: error: parse error before `}' token
> mrsiddataset.cpp: In member function `CPLErr
> MrSIDDataset::OpenZoomLevel(int)':
> mrsiddataset.cpp:1520: error: parse error before `(' token
> mrsiddataset.cpp:1522: error: parse error before `oException'
> mrsiddataset.cpp:1531: warning: ISO C++ forbids declaration of
> `poDefaultPixel'
> with no type
> mrsiddataset.cpp:1531: error: `int poDefaultPixel' used prior to
> declaration
> mrsiddataset.cpp:1531: error: parse error before `(' token
> mrsiddataset.cpp:1532: warning: ISO C++ forbids declaration of
> `eSampleType'
> with no type
> mrsiddataset.cpp:1532: error: `int eSampleType' used prior to
> declaration
> mrsiddataset.cpp:1533: warning: ISO C++ forbids declaration of
> `poColorSpace'
> with no type
> mrsiddataset.cpp:1533: error: `int poColorSpace' used prior to
> declaration
> mrsiddataset.cpp:1533: error: parse error before `(' token
> mrsiddataset.cpp:1554: warning: ISO C++ forbids declaration of
> `nRasterXSize'
> with no type
> mrsiddataset.cpp:1555: warning: ISO C++ forbids declaration of
> `nRasterYSize'
> with no type
> mrsiddataset.cpp:1556: warning: ISO C++ forbids declaration of `nBands'
> with no
> type
> mrsiddataset.cpp:1563: error: parse error before `if'
> mrsiddataset.cpp:1573: warning: ISO C++ forbids declaration of
> `adfGeoTransform
> ' with no type
> mrsiddataset.cpp:1573: error: invalid initializer
> mrsiddataset.cpp:1574: warning: ISO C++ forbids declaration of
> `adfGeoTransform
> ' with no type
> mrsiddataset.cpp:1574: error: conflicting types for `int
> adfGeoTransform[3]'
> mrsiddataset.cpp:1573: error: previous declaration as `int
> adfGeoTransform[0]'
> mrsiddataset.cpp:1575: warning: ISO C++ forbids declaration of
> `bHasGeoTransfom
> ' with no type
> mrsiddataset.cpp:1576: error: parse error before `}' token
> mrsiddataset.cpp:1581: warning: ISO C++ forbids declaration of
> `nRasterXSize'
> with no type
> mrsiddataset.cpp:1581: error: redefinition of `int nRasterXSize'
> mrsiddataset.cpp:1554: error: `int nRasterXSize' previously defined here
> mrsiddataset.cpp:1582: error: `nCurrentZoomLevel' was not declared in
> this
> scope
> mrsiddataset.cpp:1583: warning: ISO C++ forbids declaration of
> `nRasterYSize'
> with no type
> mrsiddataset.cpp:1583: error: redefinition of `int nRasterYSize'
> mrsiddataset.cpp:1555: error: `int nRasterYSize' previously defined here
> mrsiddataset.cpp:1584: error: `nCurrentZoomLevel' was not declared in
> this
> scope
> mrsiddataset.cpp:1585: error: parse error before `}' token
> mrsiddataset.cpp:1592: error: `iZoom' was not declared in this scope
> mrsiddataset.cpp:1592: warning: ISO C++ forbids declaration of
> `CPLDebug' with
> no type
> mrsiddataset.cpp:1592: error: `int CPLDebug' redeclared as different
> kind of
> symbol
> ../../port/cpl_error.h:124: error: previous declaration of `void
> CPLDebug(const
> char*, const char*, ...)'
> mrsiddataset.cpp:1592: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:1599: error: parse error before `for'
> mrsiddataset.cpp:1599: error: syntax error before `<=' token
> mrsiddataset.cpp:1599: error: syntax error before `++' token
> mrsiddataset.cpp: In static member function `static GDALDataset*
> MrSIDDataset::Open(GDALOpenInfo*)':
> mrsiddataset.cpp:1628: error: 'class MrSIDDataset' has no member named '
> poFilename'
> mrsiddataset.cpp:1628: error: parse error before `(' token
> mrsiddataset.cpp:1629: error: 'class MrSIDDataset' has no member named '
> poMrSidFile'
> mrsiddataset.cpp:1629: error: parse error before `(' token
> mrsiddataset.cpp:1631: error: parse error before `oException'
> mrsiddataset.cpp:1638: error: syntax error before `::' token
> mrsiddataset.cpp:1643: error: syntax error before `->' token
> mrsiddataset.cpp:1651: error: `i' was not declared in this scope
> mrsiddataset.cpp:1656: error: parse error before `do'
> mrsiddataset.cpp:1663: error: syntax error before `->' token
> mrsiddataset.cpp:1665: error: `pszElement' was not declared in this
> scope
> mrsiddataset.cpp:1665: warning: ISO C++ forbids declaration of
> `VSIFree' with
> no type
> mrsiddataset.cpp:1665: error: `int VSIFree' redeclared as different
> kind of
> symbol
> ../../port/cpl_vsi.h:222: error: previous declaration of `void
> VSIFree(void*)'
> mrsiddataset.cpp:1666: warning: ISO C++ forbids declaration of
> `VSIFree' with
> no type
> mrsiddataset.cpp:1666: error: redefinition of `int VSIFree'
> mrsiddataset.cpp:1665: error: `int VSIFree' previously defined here
> mrsiddataset.cpp:1666: warning: invalid conversion from `char*' to `int'
> mrsiddataset.cpp:1667: error: syntax error before `++' token
> mrsiddataset.cpp:1671: error: syntax error before `->' token
> mrsiddataset.cpp:1676: error: syntax error before `->' token
> mrsiddataset.cpp:1682: error: syntax error before `->' token
> mrsiddataset.cpp:1685: error: `poDS' was not declared in this scope
> mrsiddataset.cpp:1685: error: parse error before `;' token
> mrsiddataset.cpp:1685: error: syntax error before `++' token
> mrsiddataset.cpp:1689: error: syntax error before `->' token
> mrsiddataset.cpp:1691: error: syntax error before `->' token
> mrsiddataset.cpp:1699: error: syntax error before `->' token
> mrsiddataset.cpp:1703: error: `poDS' was not declared in this scope
> mrsiddataset.cpp:1704: error: `poDS' was not declared in this scope
> mrsiddataset.cpp:1704: warning: ISO C++ forbids declaration of
> `CPLDebug' with
> no type
> mrsiddataset.cpp:1704: error: redefinition of `int CPLDebug'
> mrsiddataset.cpp:1592: error: `int CPLDebug' previously defined here
> mrsiddataset.cpp:1704: warning: initializer list being treated as
> compound
> expression
> mrsiddataset.cpp:1706: error: parse error before `return'
> mrsiddataset.cpp: In function `void
> __static_initialization_and_destruction_0(int, int)':
> mrsiddataset.cpp:1574: warning: statement with no effect
> make[2]: *** [../o/mrsiddataset.o] Error 1
> make[1]: *** [mrsid-install-obj] Error 2
> make: *** [frmts-target] Error 2
> Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
> Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
> --__--__--
> Gdal-dev at remotesensing.org
> End of Gdal-dev Digest
