[Gdal-dev] max number of simplesources in vrt rasterband?
Vincent Schut
schut at sarvision.com
Wed Feb 4 09:27:00 EST 2004
On Tuesday 03 February 2004 18:28, Frank Warmerdam wrote:
> Vincent Schut wrote:
> > Folks,
> > I have a vrt file with approx. 1800 simplesource items (SRTM tiles). Gdal
> > always gives an error (with gdalinfo, gdal_translate, ...) for the 1020th
> > file in the vrt file. If I try to open this individual raster file with
> > gdal, everything goes fine. If I change the order of the simplesources,
> > the error still comes at the 1020th simplesource (which is another raster
> > file then) So I suspect there is a maximum at the number of simplesources
> > that can be defined in one vrt file?
> > If so, is it possible to enlarge this number?
> Vincent,
> The limit is on the number of open files on your system I would imagine.
> Depending on what operating system you are working on you may be able to
> increase the limit. But the underlying solution would be to have the VRT
> code know to only open necessary datasets to satisfy a request, or perhaps
> to close and open datasets as needed to keep under some provided file
> handle limit. I don't see that happening immediately though.
> Best regards,
Frank,
indeed, the obvious solution was `ulimit -n <many more than 1024>` ... :-)
Works like a charm now!
Thanks,
Vincent.
