R: [Gdal-dev] trivial (?) optimization for gdal.i:GDALReadRaster( )
Alessandro Amici
alexamici at fastwebnet.it
Thu Feb 5 07:19:28 EST 2004
[back to the list]
Vincent,
> > but, you are not going to get any speed gain WRT the current cvs. for
> > real zero-copy i had to patch some more files in non trivial and non
> > backward compatible way.
> I understood that. But I *am* going to have the extra numarray
> functionality, like the better array indexing support on gdal loaded raster
> arrays, I suppose?
i guess so, i'm experimenting right now.
if you want to help testing you may try out the attached patch, just define
the environment variable GDAL_PYTHON_NUMARRAY to anything and you get
numarray support :).
if it survives to basic testing i can put the patch into cvs.
cheers,
alessandro
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040205/1ad9fdb6/numarray-experimental.bin
