R: [Gdal-dev] trivial (?) optimization for gdal.i:GDALReadRaster(
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 5 10:47:33 EST 2004
Alessandro Amici wrote:
> BTW, what is the use of the numpy dataset anyhow? it doesn't appear in the
> gdalinfo list of supported formats and i didn't see it being used anywhere
> inside the python module... ??
Alessandro,
The intention is that it allows a numpy array to be accessed as a GDAL
dataset. This is primarily used in OpenEV, where you can create a numpy
array and then directly visualize it without saving it to disk or copying
the data. Likewise, most numpy use related to GDAL is in OpenEV or
derived commercial products at Atlantis.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
