[Gdal-dev] Using OGR Python to analyse stream layers
Christopher Fonnesbeck chris at fonnesbeck.org
Mon Feb 9 18:29:18 EST 2004
On Feb 9, 2004, at 1:03 PM, Frank Warmerdam wrote:
> OGR does not support much in the way of geometry intersection
> operations.
> What it does offer is a bounding box spatial filtering.  That is, a
> rectangular bounding box can be set as a spatial filter, and then when
> you iterate through the features, only those intersecting that bounding
> box will be returned.
What about the Intersect method within the Geometry class? Does that
use a bounding box, or is it a true intersection?
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
