[Gdal-dev] problem with new pyton-gdal
Silke Reimer
Silke.Reimer at intevation.de
Tue Feb 10 11:26:54 EST 2004
On Tue, Feb 10, 2004 at 10:52:03AM -0500, Frank Warmerdam wrote:
> Fulko van Westrenen wrote:
> >IndexError: No layer BOYLAT on datasource
> >GetLayerCount() reports 4 layers, there should be 57(?)
> >Downgrading is not an option. Does anyone have an idea what is wrong?
> Fulko,
> The problem is that the S-57 reader can't find the S-57 .csv files such as
> s57objectclasses.csv. Normally these would be installed in
> /usr/local/share/gdal, are they on your system?
Being the debian maintainer of gdal I checked whether
s57objectclasses.csv is in the corresponding packages. It is indeed
included in libgdal1_1.2+cvs.031111-1_i386.deb but will be located
in /usr/share/gdal after installation. Am I right, that libgdal1 is
installed on your system as well.
In this case this seems to be a bug in my package. Could you then
please file a bug? I will provide a new release to fix the bug as
soon as possible.
Frank, is it possible, that the function CPLFinderInit in
port/cpl_findfile.cpp is responsible for the searchpaths to finding
the right file? In this case $prefix/share/gdal should be added to
the FinderLocations or am I completely wrong? I don't know the code
too well.
Greetings,
Silke
BTW: Is there any plan to release gdal 1.2.0? I am not too glad with
the CVS-version of gdal in debian. An official stable release would
be much better.
> In any event, you can likely get things working by setting the GDAL_DATA
> environment variable to point to the directory with the .csv files in it.
> When they aren't found the S-57 driver just makes layers from the object
> based on their geometry class instead of by object class.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
Silke Reimer
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040210/7d8a84b8/attachment.bin
