[Gdal-dev] missing libproj.so
Norman Vine nhv at cape.com
Thu Feb 12 12:28:26 EST 2004
Frank Warmerdam writes:
> Matt Wilkie wrote:
> > The command you gave me compiled okay (no errors) and I copied the
> > results into $prefix/bin and $prefix/lib.  However gdalwarp still
> > complains about "Unable to load PROJ.4 library (libproj.so)". Do I need
> > to symlink libproj.dll.a to libproj.so or something?
> I would suggest that, yes.
Note on further investigation
I see that there is a provision for compiling PROJ_STATIC
in ogrct.cpp but that this isn't a configurable option so you should
be able to do something like
./configure $your_gdal_configure_options
export PROJ_STATIC=1; make
and you will link against the static library and the opendll call
will not be made
perhaps PROJ_STATIC support can be added to the configure script ?
HTH
Norman
