[Gdal-dev] Data format
Ben Discoe
ben at vterrain.org
Fri Feb 13 14:23:26 EST 2004
> -----Original Message-----
> From: Clay, Bruce
> The data file I opened is a DEM file from the GTOPO30 data set.
> When I use RasterIO I get
> back a buffer full of floats. How do I interpret them?
They are elevation in meters.
> The origin is 20.0, 40.0 I assume this is latitude and longitude.
Yes.
> The pixel size is 0.008333, -0.008333. Does this represent
> the distance between values in degrees?
Yes.
> What does the negative number represent?
The fact that pixel sizes are measured from the top-left corner downward,
which is the negative latitude direction.
> The GetRasterxxx methods say that the file data 4800 x 6000 x 1.
> Does this mean that only the elevation data is in the file?
Yes. Were you expecting something more in a GTOPO file?
> The bands are reported to be 4800 wide. Based on the file names
> in the GTOPO30 data set it looks like they cover 40 Deg. Longitude
> but differing coverage in latitude.
Yes.
> I am trying to find the elevation for specific coordinates based
> on latitude and longitude input.
You have the corner and the extents, so it's simple arithmetic to compute
the offset based on an input, X,Y = (input-corner)/pixel_size
> Sorry if these are dumb questions.
We're all beginners at some point :)
-Ben
