[Gdal-dev] GML procesing problems
Sat Feb 14 12:39:03 EST 2004
Andrew Larcombe wrote:
> Hello all,
> I am having problems processing GML files created using the ogr2ogr program.
> This is what I have done:
> 1. Create a simple GML file from a .shp file (airports) contained in the UMN
> Mapserver itasca data set using the following command:
> [andrew at server andrew]$ ogr2ogr -f "GML" ~/airports.gml ./airports.shp
> This produces the files airports.gml and the corresponding schema file
> airports.xsd.
> 2. I have created a very simple stylesheet and attempted to process the GML
> file using the XSL file using the Apache Xalan-C transformer, but this
> generates the following error:
> [andrew at server andrew]$ Xalan airports.gml airports.xsl
> Fatal Error at (file airports.gml , line 5 , column {null} ): The prefix 'ogr'
> has not been mapped to any URI
> SAXParseException: The prefix 'ogr' has not been mapped to any URI
> (airports.gml, line 5, column 45)
> 3. Opening the GML file in an XML editor and attempting to validate it, or
> specify an XPath filter produces similar results.
> Can anyone help?
Andrew,
This problem was recently fixed in the GML driver (a few weeks ago).  I would
suggest you try again building from a CVS nightly snapshot.  Alternatively,
if that is impractical for some reason, I could provide details on the patch
to fix the problem.
Best regards,
