[Gdal-dev] ogr virtual data issues with connecting to excel
Normand Savard
nsavard at dmsolutions.ca
Mon Feb 16 09:13:14 EST 2004
Tom,
You could verify your connection with the Excel driver by using this
small application: ODBCView:
http://asia.cnet.com/downloads/pc/swinfo/0,39000587,39034753s,00.htm
Norm
Kralidis,Tom [Burlington] wrote:
>Hi,
>I'm trying to connect to an excel document using this approach, but am
>having problems doing so.
>I have created a system DSN
>Here is my .ovf file:
><OGRVRTDataSource>
> <OGRVRTLayer name="plantwatch">
> <SrcDataSource>ODBC:plantwatch2,plantwatch</SrcDataSource>
> <SrcLayer>plantwatch</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="longitude"
>y="latitude"/>
> </OGRVRTLayer>
></OGRVRTDataSource>
>When I test with ogrinfo, I get:
>C:\ms4w\Apache\cgi-bin\ms_odbc>.\ogrinfo.exe
>\ms4w\mapserv\services\naturewatch\plantwatch2.ovf
>ERROR 4: Update access not supported for VRT datasources.
>ERROR 1: Unable to identify source X or Y field for PointFromColumns
>encoding.
>FAILURE:
>Any suggestions? The x and y attributes exist as columns in my excel file.
>As a workaround, when I converted the excel file to an access database, it
>worked.
>I can post the excel document on request.
>Thanks
>..Tom
>Tom Kralidis
>Systems Scientist
>Environment Canada
>Tel: +01-905-336-4409
>http://www.ec.gc.ca/cise/
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
