[Gdal-dev] Problems building gdal dll with libtool on MinGW
Mario Beauchamp
starged at videotron.ca
Thu Feb 19 00:02:46 EST 2004
Hi Alessandro,
On Wed, 18 Feb 2004 09:52:38 +0100, Alessandro Amici <alexamici at fastwebnet.it> wrote:
>why did you go for dev-cpp for building the static library (which i belive is
>a lot of work!)? did you have any problem with the gdal static build?
I feel more comfortable in a IDE... hate the command-line stuff :)
And yes, it's a lot of work but you only have to do it once.
>i'd think that just doing 'configure' 'make' 'make install' 'a2dll' should
>work as well
Up to yesterday, that's the way I was doing it... just got tired of it.
Mario B.
My Landsat images:
http://pages.infinit.net/starged/landsat/home.html
