[Gdal-dev] Radical OGR Update
Alessandro Amici
alexamici at fastwebnet.it
Thu Feb 19 04:49:50 EST 2004
Andrey,
On Thursday 19 February 2004 09:50, Andrey Kiselev wrote:
> > It seems that if I am going to make a change of this magnitude, it
> > would be best to do so before the 1.2.0 release cycle.
> Those changes will take a time for implementing and especially for
> testing. What about releasing GDAL 1.1.10 shortly?
1.2.0 is more appropriate since you need to change the link option (WRT to
1.1.9) for external application. unless you are using 1.1.9 on debian ;)
> libtool environment
> seems to work good: GDAL builds on all 9 Debian architectures, it builds
> in native MinGW and Cygwin environments and it even builds with my old
> MinGW cross-compiler (and Alessandro reported it builds with the newer
> cross-compiler on Debian unstable). So it seems to be more robust than
> previous build system.
my most amazing target was an old alpha with gcc 2.8.? and native (non-gnu)
ld.
cheers,
alessandro
