[Gdal-dev] Problem with Python, OGR/OGDI and VPF.
Eggert Jón Magnússon
ejm at gavia.is
Thu Feb 19 05:09:59 EST 2004
Your script reproduces the problem on my end.
layer relline at rel(*)_line with 35 features.
gt 2
layer relpoint at rel(*)_point with 2 features.
gt 1
I am running on windows XP, and am using version 3.1.0 of ogdi (latest
binary release), and gdal 1.1.9.
I have not yet felt brave enough to compile ogdi for windows - but I am
getting there :)
regards,
Eggert
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Frank Warmerdam
Sent: 18. febrúar 2004 19:20
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Problem with Python, OGR/OGDI and
VPF.http://www.esri.com/devsupport/devconn/mapobjects/samples/vb/vpfsamp
les/vpfsamples.zip
Eggert Jón Magnússon wrote:
> I am having problems reading a VPF database through OGDI/OGR in python.
> When I try to call ds.GetLayer(layerCount-2), something locks up.
> I am not sure on which end the lockup is (whether OGR is waiting for
OGDI?)
> but ogrinfo displays the layer names correctly.
> The dataset I am using is the formerly publically available sample VPF
> dataset, San Diego Harbor. (I managed to obtain it from the ESRI
homepage:
http://www.esri.com/devsupport/devconn/mapobjects/samples/vb/vpfsamples/vpfs
> amples.zip)
> Here is the snippet of code that manages to lock up:
> for i in range(file.GetLayerCount()):
> layer = file.GetLayer(i)
> print 'layer %s with %d
> features.'%(layer.GetName(),layer.GetFeatureCount())
> gt = layer.GetLayerDefn().GetGeomType()
> print 'gt',gt
> if gt == 3:
> obClass = Area
> append = self.polygons.append
> elif gt == 2:
> obClass = Line
> append = self.lines.append
> else: # gt == 1: Point
> obClass = None
> continue
> What happens is that I get a printout of all the layers except the last 2
> ones, and the process locks up.
Eggert,
I just tried the following script with the dataset you referenced, and it
seemed to work fine.
import ogr
file = ogr.Open( 'gltp:/vrf/dnc13cd/H1316010' )
print 'gt',gt
It ran to completion, and seems to have reported all layers. The report
ends with:
layer dqyarea at dqy(*)_area with 21 features.
gt 3
gt 2
gt 1
layer tileref at tileref(*)_area with 2 features.
gt 3
layer libref at libref(*)_line with 270 features.
gt 2
I was doing this on Linux with current CVS versions of OGDI and GDAL/OGR.
What platform are you working on? What versions of GDAL and OGR?
Now that I am looking at the vrf driver again, I find there are some
leaks which I am digging into, but I can't imagine those would be
responsible for your problems.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
