[Gdal-dev] 1.2.0a Release
Daniel Morissette dmorissette at dmsolutions.ca
Thu Feb 19 19:00:47 EST 2004
Frank Warmerdam wrote:
> I would appreciate it if some people could give this new rev a quick
> spin on
> different platforms, and building it into different applications.
Trying to build on Solaris 8, using GCC 2.95.2, I get the following errors:
/bin/sh ../libtool --mode=compile g++ -Wall  -O2   -I../port  -c -o
cpl_vsisimple.o cpl_vsisimple.cpp
  g++ -Wall -O2 -I../port -c cpl_vsisimple.cpp  -fPIC -DPIC -o
.libs/cpl_vsisimple.o
cpl_vsisimple.cpp: In function `struct tm * VSIGMTime(const time_t *, tm
cpl_vsisimple.cpp:445: implicit declaration of function `int gmtime_r(...)'
cpl_vsisimple.cpp: In function `struct tm * VSILocalTime(const time_t *,
tm *)':
cpl_vsisimple.cpp:463: implicit declaration of function `int
localtime_r(...)'
make: *** [cpl_vsisimple.o] Error 1
The function gmtime_r() is available in <time.h>, but for some reason
the prototype is not found (it is protected by a few #ifdefs in time.h).
The Solaris man pages talk about defining _POSIX_C_SOURCE to a value >=
199506L.  I tried that but then started getting problems with strdup()
in cpl_vsisimple.cpp.  Looking in <string.h> it seems that this function
isn't available when _POSIX_C_SOURCE is defined.
OK. To make a long story short, I have removed HAVE_GMTIME_R and
HAVE_LOCALTIME_R in cpl_config.h and my compilation continues.
What should we do about this?  Should we put a test specific to Solaris
in configure?  Is this a problem that could apply to other platforms?  I
have to admit that I'm not familiar with this _POSIX_C_SOURCE define.
BTW, we'll be probably compiling on AIX 4.3 in a few days... so stay
tuned... that promises to be fun (64 bits!).
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
