[Gdal-dev] 1.2.0a Release
Sat Feb 21 14:17:12 EST 2004
Alessandro Amici wrote:
> the dependency libraries are _only_ useful if you link against the static
> version of gdal, i.e. libgdal.a. they are _not_ needed in the normal case
> when you link against gdal as a shared library (at least on linux).
Alessandro,
OK, I concur that the dependencies should not appear in the --libs
output if they aren't needed to link against whatever GDAL library is
listed in --libs.
I have had reports that on MacOS the shared libraries do not carry
their dependencies along with them ... that the supporting libraries
need to be explicitly listed.  Can anyone confirm that?  Can anyone provide
an account on a MacOS X system I can use for build testing?
Best regards,
