[Gdal-dev] 1.2.0a Release
Norman Vine
nhv at cape.com
Sun Feb 22 02:34:59 EST 2004
Frank Warmerdam writes:
> Norman Vine wrote:
> > It would also be nice if there was a configure mechanism in gdal
> > and proj to hardwire the location of the 'shared' data in order to
> > facilitate remote installation on a machine on which one did not
> > have enough privilige to run as 'su'
> Have you tried the --datadir option for the PROJ.4 configure? I am not
> sure if it works, but I think it might. I have created a 1.2.0 release
> blocking bug to make the --datadir option work with the GDAL configure.
> http://bugzilla.remotesensing.org/show_bug.cgi?id=501
> Note, that you can just edit GDALmake.opt and change INST_DATA before
> starting your build. But I realize many people seem to want to do everything
> from the configure commandline.
Frank
This sort of works for when one doesn't have 'su' privilige
./configure --prefix=XXX
but requires using $ENV variables to find the shared data
What I was suggesting was perhaps adding a configure time
option for setting a 'hardwired' location instead of relyiing on
the $ENV
I believe this would make remote instalation of mapserver easier
for those cases where 'su' rights weren't available and possibly
save some confusion for users that aren't accustomed to using
the $ENV
Then again this adds complexity ..
Cheers
Norman
