[Gdal-dev] [patch] gdalwarp: use existing destination file spatial reference set
Manuel Massing
gdal at warped-space.de
Wed Feb 25 14:36:45 EST 2004
Hello,
I just wanted to suggest the attached patch to apps/gdalwarp.cpp. Currently,
gdalwarp does not honor the spatial reference set of an existing destination
file. I'm not sure if this behavior is the intended one, and it seems
somewhat inconsistent with other options pertaining to target format
specification (size, resolution, extent).
It might be desirable to permit an overridden specification of the target
spatial reference, though. If you feel this is the case, I'll post a revised
patch.
BTW, also attached is a tiny bugfix for alg/gdalwarper.cpp :-)
cheers,
Manuel
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040225/825cb602/gdalwarper_cpp.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040225/825cb602/gdalwarp_cpp.bin
