[Gdal-dev] [patch] gdalwarp: use existing destination file spatial reference set
Manuel Massing
m.massing at warped-space.de
Wed Feb 25 13:34:12 EST 2004
Hello,
I just wanted to suggest the attached patch to apps/gdalwarp.cpp. Currently,
gdalwarp does not honor the spatial reference set of an existing destination
file. I'm not sure if this behaviour is the intended one, and somewhat
inconsistent with other options pertaining to target format specification
(size, resolution, extent).
It might be desirable to permit an overriden specification of the target
spatial reference, though. If you feel this is the case, I'll post a revised
patch.
BTW, also attached is a tiny bugfix for alg/gdalwarper.cpp :-)
cheers,
Manuel
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040225/9d188eed/gdalwarper_cpp.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040225/9d188eed/gdalwarp_cpp.bin
