[Gdal-dev] Debug Assertion Failed!
Fu Chen chen at yinyue123.com
Mon Jan 12 22:10:59 EST 2004
Hi!
I face the same trouble before. You should rebuild the gdal in /Md when
you try to use it in debug mode.
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Weimin Wang
Sent: Tuesday, January 13, 2004 9:36 AM
To: gdal-dev at remotesensing.org
Subject: [Gdal-dev] Debug Assertion Failed!
Hello,everyone,
GDALOpen function was used to open RS image under Windows platform.No
error was found during the compilation and linking process with "Win32
Debug" mode.However,when i run the program and execute the GDALOpen
function.It is said "Debug Assertion Failed!
Program: J:\...
File: dbgheap.c
Line: 1044
Expression: _CrtIsValidHeapPointer(pUserData)"
This problem disppeared for "Win32 Release" mode.
How do this error occur?Any suggestion be thankful!
Best Regards,
Wang Weimin
WaterCenter,Institute of Geo.
Sci. & Nature Resource Research,
Chinese Academy of Science,
Beijing,100101,China
http://qtirsl.igsnrr.ac.cn
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
