[Gdal-dev] ogr getnextfeature problem
Vladimir Slepnev
slepnev_v at newmail.ru
Wed Jan 14 07:40:44 EST 2004
Hello,
I seem to be having a problem importing some shapefiles using OGR. When
importing some GSHHS line data, OGR simply crashes on a GetNextFeature
call somewhere near the middle of the feature list. When importing a
dspoint.shp file (drainage data frow the DCW), not all the points seem
to get imported - the points get clipped to a rectangle in geographic
coordinates. The reason for the problem seems to be that OGR uses .shx
files.
I do not send the files because they are several megabytes in size.
Vladimir Slepnev
Programmer, RDC ScanEx
