[Gdal-dev] Implementing GDALRasterBand::IRasterIO
James Gallagher
jgallagher at gso.uri.edu
Thu Jan 15 17:53:41 EST 2004
Frank, et al.,
I'm busy implementing IRasterIO() and I'd like to know the best way to
test my (at this point partial) implementation. I have a little test
program that does:
int nXSize = poBand->GetXSize();
int nYSize = poBand->GetYSize();
float *pafData = (float *) CPLMalloc(sizeof(float)*nXSize*nYSize);
poBand->RasterIO(GF_Read, 0, 0, nXSize, nYSize,
pafData, nXSize, nYSize, GDT_Float32,
0, 0);
But I was wondering if one of the programs in apps was more of an
'official' test program for a new driver.
A few misc. questions: Are band numbers indexed using a ones-based
scheme? How about the n{X,Y}Offset parameters? From the docs it looks
like ban numbers *do* use ones-based indexing, but I want to be sure.
Same for the offsets.
Thanks,
James
On Wed, 2004-01-14 at 12:01, Frank Warmerdam wrote:
> James Gallagher wrote:
> > Hi,
> > I would like to add sub-sampling capabilities to the OPeNDAP/GDAL
> > driver. To do this I plan on specializing GDALRasterBand::IRasterIO().
> > First question: is that method the correct place to implement
> > sub-sampling?
> James,
> It depends a bit what you mean by sub-sampling. If you want a client
> application to be able to request a sub-area at full resolution and
> the driver would be able to fetch just the subarea then overriding
> IRasterIO() would be one approach. Another would be to pretend that
> the data is tiled, and just implement the IBlockRead() method.
> If you want to offer an efficient way to accessed reduced resolution
> images, then you could produce pseudo-overview layers.
> However, given that for the OPeNDAP driver you want alot of control
> over how many individual requests actually go to the remote server,
> I would say overriding IRasterIO() makes sense.
> Be aware that:
> o applications normally call RasterIO(), so you will now very rarely
> get block accesses - however, it can still happen. For instance, I
> think the min/max computation goes through the block API.
> o It is very common for applications to make many small RasterIO()
> calls, often for one scanline at a time. I often try to recognise
> the scanline request case, and pre-read a bunch of scanlines at once
> and cache them.
> > Second question: I noticed that the OGDI driver implemented only the
> > GDALRasterBand::IRasterIO method while the ECW driver implemented it's
> > own version of both that and GDALDataset:IRasterIO. What are the
> > implications of specializing the second method?
> You would implement a custom GDALDataset::IRasterIO() if you want a more
> efficient access to multi-band datasets as a single request. For instance,
> ECW implements GDALDataset::IRasterIO() because it is much cheaper to pass
> one request on to the ECW API for all the bands of an image at once,
> instead of requesting them one at a time.
> By the way, one of the applications that we want the GDAL/OPeNDAP driver to
> be good with is MapServer. MapServer currently always makes one big
> RasterIO() request for whatever it needs for each band being read. Eventually
> I hope to change this to utilize the GDALDataset::RasterIO() entry point for
> greater efficiency where that is specialized. So, overriding
> GDALRasterBand::IRasterIO() or GDALDataset::IRasterIO() will give a big win
> for MapServer.
> In fact, you might consider just overriding the GDALDataaset::IRasterIO(), and
> doing an implementation of GDALRasterBand::IRasterIO() that calls the dataset
> level one with a single band requested. That would set you up optimally for
> future improvements in MapServer.
> Applications like OpenEV are going to make lots of "tile by tile" RasterIO()
> requests to GDAL. This would presumably turn into a remote request for each
> tile which is sensible, but will add a real latency drag into OpenEV renders.
> Batch applications are usually scanline based, via RasterIO(), and as mentioned
> before it would a wise idea to recognise this case, and force some sort of
> chunking.
> One final note, when you implement IRasterIO() you avoid data going through
> the GDAL cache. That is good if you are effectively caching things yourself
> somehow, but can completely hammer you in some situations if you are not.
> Best regards,
__________________________________________________________________________
James Gallagher The Distributed Oceanographic Data System
jgallagher at gso.uri.edu http://unidata.ucar.edu/packages/dods
Voice/Fax: 406.723.8663
