[Gdal-dev] ERROR import Shape to PostgreSQL
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 16 09:29:59 EST 2004
Düster Horst wrote:
> Hallo
> Today I made an upgrade of gdal/ogr from 1.1.7.2 to cvs-040114. GDAL-1.1.7.2
> works very stable but I need to convert POLYGON to MULTIPOLYGON. Hence I
> made the upgrade. But now I'm not able to convert ESRI Shape to PostgreSQL
> in all cases. So some shapes which could be imported by the former Version
> of GDAL without problems breakes down the import process with the following
> error message:
> ERROR 1: INSERT command for new feature failed.
> ERROR: couldnt parse objects in GEOMETRY
> ERROR 1: Terminating translation prematurely after failed
> translation of layer lieg_lieg_geom
> I start ogr2ogr with the following command string:
> ogr2ogr -f postgresql PG:dbname=hdus lieg_lieg_geom.shp -lco overwrite=yes
> -lco launder=yes -lco precision=no -nlt MULTIPOLYGON -nln liegen
> To reproduce this error I can send the mentioned shape.
> It would be great to solve this probem.
Dr. Düster,
Sorry for not getting back to you on your earlier message ... this issue looks
hard enough that I put it off a bit. My first thought was that you were
getting multipolygons written to a polygon layer in postgis, but I see that
you selected the type multipolygon. Ogr2ogr should try and force polygons
to multipolygons as well since you have selected multipolygon output.
I am not sure what is going wrong, so I think I will need the dataset.
I would also like to know what version of postgis you are running in
case that might be a factor.
You might also want to try setting CPL_DEBUG to ON before running ogr2ogr.
I believe this will report all the SQL statements used while loading
PostGIS. Seeing the last statement might be helpful.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
