[Gdal-dev] Compiling error on Redhat 9 from gdal/ogr cvs source
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 16 12:43:29 EST 2004
Normand Savard wrote:
> Frank,
> I trying to compile gdal/ogr from source and I got a compilation error.
> I checked out the source code from cvs this morning.
> My configuration setting is:
> ./configure --prefix=/opt/mapserver/ --with-ogr
> --with-png=/opt/mapserver/ --with-libz=/opt/mapserver/
> --with-jpeg=/opt/mapserver/ --with-odbc=/usr/local
> I did a "make" and I got the error below.
> I checked in the source code and the "VSIStrerror()" is declared in
> "cpl_vsi.h" via an "cpl_conv.h" include. The function appears in
> "cpl_vsisimple.cpp" file.
> The error is:
> make[2]: Entering directory `/home/src/gdal-cvs/frmts/hfa'
> /bin/sh ../../libtool --mode=compile g++ -Wall -O2 -I/opt/mapserver/
> -I/opt/mapserv
> er//include -I/opt/mapserver/ -I/opt/mapserver//include -I../../port
> -I../../gcore-I../../ogr -c -o ../o/hfaband.o hfaband.cpp
> g++ -Wall -O2 -I/opt/mapserver/ -I/opt/mapserver//include
> apserver//include -I../../port -I../../gcore -I../../ogr -c hfaband.cpp
> -fPIC -DPIC-o ../o/.libs/hfaband.o
> hfaband.cpp: In member function `CPLErr HFABand::GetRasterBlock(int, int,
> void*)':
> hfaband.cpp:878: `VSIStrerror' undeclared (first use this function)
> hfaband.cpp:878: (Each undeclared identifier is reported only once for each
> function it appears in.)
> make[2]: *** [../o/hfaband.o] Error 1
> make[2]: Leaving directory `/home/src/gdal-cvs/frmts/hfa'
> make[1]: *** [hfa-install-obj] Error 2
Normand,
Any chance you have an old cpl_vsi.h sitting around in /opt/mapserver/include
or /opt/mapserver? If so, try deleting it.
Andrey, could you review the frmts/hfa GNUmakefile and see if it needs
the include directives reordered?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
