AW: [Gdal-dev] ERROR import Shape to PostgreSQL
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 19 14:00:54 EST 2004
Düster Horst wrote:
> Frank
> I found out that the -lco OVERWRITE=YES support in the postgis driver don't
> delete an existing record in geometry_columns.
> The error message:
> ERROR 1: AddGeometryColumn failed for layer kva_av_liegen_tmp, layer
> creation has failed.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer lieg_lieg_geom
> When I delete the record ogr2ogr works fine.
Dr. Düster,
I found that with my current PostgreSQL the DROP TABLE command gets rid of
the sequence (%s_ogc_fid_seq), but that the failure of the DROP SEQUENCE
command following it was triggering a rollback of the DROP TABLE command.
I changed around the DeleteLayer() code a bit, and now things seem to work.
Of course, any layers that were half deleted might need to be cleaned up as
you suggest.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
