[Gdal-dev] DEM Files
Mon Jan 19 16:33:14 EST 2004
Martin Chapman wrote:
> I am using gdal to load and display usgs ascii dem files with opengl on
> windows.  When I load the file everything works fine but all the
> elevation values are all -32000.  Has anyone ever had this problem
> before?  I am basically using RasterIO to read line by line of the file
> and then storing the values into a 2D array.
Martin,
I have encountered USGS DEM files that were mostly the -32000 background value,
but I think there should be *some* real values.  If you think the file is not
being read properly you could email it directly to me, and I will check it
out.
Best regards,
