[Gdal-dev] nad27 problem?
Tom Parker tapadmin at swbell.net
Mon Jan 19 21:47:14 EST 2004
I've gone ahead and undone the make install steps by deleting all the
relevant files from /usr/local and just added my user development paths to
LD_LIBRARY_PATH in .bash_profile
/home/tparker/lib/gdal/.libs/
/home/tparker/lib/proj/src/.libs/
And it works without a problem now. Hmmm?
I can keep working now but I'm not familiar enough with the code to guess
the problem when it's installed.
Regards
Tom
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Tom Parker
Sent: Monday, January 19, 2004 8:02 PM
To: gdal-dev at remotesensing.org
Subject: RE: [Gdal-dev] nad27 problem?
Actually I just tried it again with gdalwarp instead of my code and get the
same error message.
gdalwarp -t_srs '+proj=utm +zone=14 data=WGS84' oklahoma_city-w.dem
okc-temp.tif
generates the same error so I'm hoping it's just a configuration problem.
I'd be happy to try other files and projections if you can point me at them.
Thanks
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Ed McNierney
Sent: Monday, January 19, 2004 7:44 PM
Tom -
Are you successfully reprojecting OTHER files, and only having a problem
with a specific zone 14 target, or are you failing to reproject
anything?
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
Sent: Monday, January 19, 2004 8:25 PM
To: gdal-dev
Subject: [Gdal-dev] nad27 problem?
Hello,
I'm porting an application from windows to linux and have run into a
puzzling problem while attempting to project a USGS dem file to UTM zone
14.
I'm using the current gdal and proj from cvs on a fully patched redhat 9
system and have run configure, make and make install on both projects
with default arguments.
The problem is the projection routine is failing and giving me the error
message.
ERROR 1: failed to load NAD27-83 correction file ...
ERROR 1: failed to load NAD27-83 correction file ERROR 1: Reprojection
failed, err = -38, further errors will be suppressed on the transform
object.
I've tried a few ideas from searches of the mailing list:
- uncompressing the original files from the archive to make sure no
windows <=> linux silliness is happening.
- using gdalinfo to make sure the dem file is readable, everything looks
normal.
- setting PROJ_LIB=/usr/local/share/proj/
- adding printf statements to LoadProjLibrary in ogrct.cpp to make sure
the library was really loading, it is with no issues I can see.
I'm a bit stumped :(
Any ideas would be greatly appreciated.
Regards,
Tom
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
